PsExec.exe Runing on labview2012 with System Exec.vi
I have problem on this,it report erroe to run PsExec.exe using "System Exec.vi". It runs well on Labview8.6 version,but has problems on Labview2012. Could someone give some help?
Message 1 of 8
(3,850 Views)
Which error does it report?
What is "PSExec.exe"?
How do you call it?
Did you change the PC or the OS too or just used a newer LabVIEW version?
Message 2 of 8
(3,829 Views)
Checked with LabVIEW 2013 and works without any problems.
Which error exactly you have?
One point for PsExec - when it runs first time on the PC, then EULA dialog is coming up and needs to be accepted. If you set flag Run Minimized, then this dialog will be "invisible", but SystemExec will wait for acknowledgement.
Hint - you can set up registry flag EulaAccepted in HKCU\Software\Sysinternals\PsExec to 1 (DWORD) - then this dialog will be suppressed.
Andrey.
Message 3 of 8
(3,817 Views)
Should this works?but it report the error
Message 4 of 8
(3,808 Views)
Accepted by topic author ll48263046
What about using "cmd /c PsExec.exe" as command string?
Message 5 of 8
(3,799 Views)
Are you sure that PsExec placed into the directory which is in PATH variable.
Try to give full path to PsExec.exe. For example, copy this utility to C:\ and then call it as C:\PsExec.exe.
Message 6 of 8
(3,796 Views)
Thanks a lot.
It works now, the Labview 2012 are strict at this, i am sure to try this but make a mistake by input "/c PsExec"
Message 7 of 8
(3,781 Views)
I tried again, it is not the cmd /c problem.It is the path problem.
Before i put it into C:\windows\system32 ,it didn't work. So i put it into C:\ and make the input command to C:\\PsExec.exe .it runs well now.
But i am still confuse why put it into system32 it didn't work, and report the error 'psExec' is not recognized as an internal or external command,
operable program or batch file."
Message 8 of 8
(3,774 Views)
