Pulsatile Linear Actuator Control - Help Needed
I have a VI that controls the speed of a linear actuator, which is placed within a case structure. A limit switch input switches
the case structure between forward and reverse. This allows the actuator to move in a continuous motion either forward and
reverse. What I would like to achieve is a pulsatile movement. The linear actuator operates for a set time and completely off
for a set time.
I have tried various approaches with the elapsed time function, alternating wait times but just can't seem to get this, any help
would be greatly appreciated, I have attached the VI.
Ger
(3,268 Views)
A few things:
Are you using the Run Continuously button?
If so, stop and put this into a proper loop or state machine.
I don't think the Elapsed Time function is what you're looking for.
I think you want to use Time Delays between changing the output on your digitals.
Take some time with the LabVIEW tutorials. They'll help you a bunch here.
(3,260 Views)
Hi Taki1999,
Thanks for your help, I've gone through the tutorials and understand the usage of the timing functions but I am
mainly stuck on how to best use them to achieve the ON/OFF that I am looking for. Any help would be great.
Regards
Ger
(3,222 Views)
Accepted by GOB82
Try a state machine.
When forward button is on, alternate between a off and on state for forward with a wait inside.
Same handling for reverse.
(3,190 Views)
