Pulse Amplitude, Delay settings
All the others are working in pulse setting, but not the pulse amplitude and delay
can someone tell me what is wrong?
thanks,
(2,957 Views)
The VI HP8133A Pulse Channel Setting has been mucked up. It doesn't match the version that I downloaded. The equal comparison should be equal to 3 - not 0.
I don't understand your comment about the amplitude. You are setting the high and low of the pulse and you are doing this after you set the amplitude/offset. Do one or the other. If you program an amplitude/offset and then your high and low don't agree, then it is the high and low that will be programmed because you are setting those after. If the instrument is being programmed to match your high and low settings, then everything is working.
(2,953 Views)
I did not understand what do you mean by that the VI HP8133A Pulse Channel Setting has been 'mucked up'? Could you explain what do you mean by 'equal comparison' statement?
In the attached/updated VI, the phase setting was removed.
So, it is the last two voltage setting parameters that will set (High & Low) final voltage levels? Cannot figure out why 'delay' setting does not change?
I cannot seem to find any major error with VI 'HP81333A application Function_mod2'
(2,924 Views)
Here's a picture of the incorrect modification you made. The cases are backwards as well. The true case should set the period and and the false case should set all others. Why don't you just re-download the driver?
Message Edited by Dennis Knutson on 06-21-2006 04:05 PM
Message Edited by Dennis Knutson on 06-21-2006 04:09 PM
(2,927 Views)
Thank yoU!
(2,891 Views)
