Pulse Measurements vi modification
I am currently using LabVIEW 7.0.
The pulse measurements vi histogram method uses the 40% lower and upper histograms to find the low and high state levels.
My application requires me to take a look at the 10% lower and higher histograms, does anyone has a suggestion on how to modify that vi to fit my needs?
Thank you
(2,826 Views)
Just to clarify, the 40% refers to the range of the histogram that is searched to find the peak histogram levels (or state levels). Then the reference levels are typically set at 10% and 90% of the resulting range defined by the two peak histogram values.
There is no way to modify the 40% histogram search range in the Pulse Measurements.vi. The alternative would be to perform a histogram separately on your input data and process it according to your requirements. The resulting reference levels can be passed into Pulse Measurements by changing the ref units input of the reference levels cluster to "absolute".
(2,826 Views)
