Stop a SubVI from the main VI
I have one VI, that has a while loop. The stop button for this main be is in a "event" estructure, and works correctly. In this main VI I have a subVI, that has also a while loop. this subvi must be running all the time the main be runs, and an array of this subvi must be updated continuously in the main vi front panel. I have tried with the "control references", but I don´t know what I'm doing badly. Can someone explain me the way to do this? Thank you, I have just started using LabVIEW and this may be a silly question, sorry if so
(2,891 Views)
It is hard to explain what you may be doing wrong without seeing your code. Please post your code and let us have a look a it.
Joe.
"NOTHING IS EVER EASY"
(2,891 Views)
I attach both files, I hope you can help me to solve the problem, because I don't really know hoy control reference work. Thanks!!!
(2,891 Views)
Can you please post your Vi's saved in version 7.0 To do that all you have to do is go to file/save with options/save for previous.Do this and I will have a look to see what might be wrong.
Joe.
(2,891 Views)
Thank you for your interest. I have solved the problem just changeing the operation mode pf the stop button to "switch when released". this has solve the problem...
(2,891 Views)
