Pulse oximeter that read data from datasheet(.csv)
I realize that English is not your first language, however, data was posted and not your algorithm.   I have read your assignment and now see that your instructor's goal is to have you implement an algorithm in LABVIEW.  This is why I asked for the algorithm.  Use Google to search for Pulse oximeter Beer's Law.  Ask your instructor to help you with calculating the SAO2 and PULSE RATE by hand (no computer).
I have a few observations and suggestions to improve with your LONG-TERM learning (this will not help you with your assignment):
1) Labview = Data-Acquisition.   I suggest that you use measure an analog oximeter signal (http://tinyurl.com/oximeter1) to learn how Labview can be quickly used measure signals.  The video shows an Nellcor N600X analog pleth signal collected with MATLAB using an Arduine Due: the concept is the same.
2) MATLAB = Signal Analysis.   A mathematics package like MATLAB is the place to prototype the algorithm.  The upper plot shows your red data:
I think that because of the order in which the data is stored, the data is 'backwards': the MATLAB command fliplr() was used to create the lower graph which (from experience) depicts a more realistic pleth waveform.  I discarded the first data point and first column.    Although this is a NI board and NI has made significant progress in the last 20 years regarding signal processing, MATLAB or NumPY would be my first choice.
3) Finally, I would suggest that you focus on either the algorithm OR the data-acquisition: NOT both.  The algorithm involves Beer's law and it would be helpful (maybe necessary) to have an undergraduate EE degree.  If you are an undergraduate or in highschool I suggest using wiring a Nonin iPod 3150 oximeter to a PL2303HX Converter USB To RS232 TTL USB To COM to demonstrate that you can wire up a device correctly and read a signal.  I have mentored students serial communications and have 2 devices remaining that are 'plug and play.
Message 11 of 19
(1,834 Views)
Hi gatorback.
Thank you for your suggestion. I relized that yesterday after the comment from GerdW. I started doing everything from the start and manage to get Sp02 rate. For heart rate I will take the time between to peaks and 1/T is the heart rate.
Message 12 of 19
(1,809 Views)
Guys, How can I detect two adjacent peaks from array? And show their value and index?
P.S. I am sending you the .csv file from which I have to detect peaks.
Message 13 of 19
(1,788 Views)
Hi Gajo,
Simple algorithm:
- search first peak and show its value/index
- then search the second peak starting and index of first one +1…
Message 14 of 19
(1,783 Views)
Search it with which function?
Message 15 of 19
(1,779 Views)
Hi Gajo,
LabVIEW comes with a lot of signal processing functions, including "Peak Detection"…
What have you tried so far?
Message 16 of 19
(1,777 Views)
I tried array min and max, but that only returns one value, and peak detect but I cannot connect my array with that vi.
Message 17 of 19
(1,776 Views)
Hi Gajo,
Attach your current VI with your tries to use PeakDetection…
Message 18 of 19
(1,772 Views)
Here is the .vi
Message 19 of 19
(1,770 Views)
