Pulse width calculation for transient signal
anyone can help me with caluculation part atleast for Sine pulse signal input 30ns /40ns. as attached.
Message 11 of 15
(1,250 Views)
Hi newbee,
I repeat:
If you would provide your VI with some default/example data included
Should we use Paint to draw some lines in your images?
What's wrong with LocalDSP's example?
Message 12 of 15
(1,247 Views)
Hi GerdW,
I am sorry, since I do not know how to save data.
I gave VI in zip file, since data was not getting saved in the VI, I gave signal snapshot.
Message 13 of 15
(1,237 Views)
Hi newbee,
You should do the beginner courses to learn LabVIEW, then you should know how to use those file functions…
Or: run a measurement to have your signal as a plot in a graph. Stop the VI, set all control values as default (edit menu!), save your VI and attach it…
Damn, I told all that before!
As said several times before: you cannot debug images with LabVIEW!
Message 14 of 15
(1,232 Views)
Hi GerdW,
I did as you said when i sent zip file containing VI.
But in that only control values are getting saved. Not the data values of input signal.
Message 15 of 15
(1,220 Views)
