Pulsed Digital Output with 9401
I am trying to generate the same "pulsed" output on two lines of a 9401 module (I am using the +5V signals to "duty-cycle" drive two 2N3904 transistors).  How do I instruct these two DO lines to use a pulse train generated from a "CO Pulse Generation" task?
Ideally, I would also like to start this DO output/CO Pulse with and Analog Edge trigger (I need to start the output pulses to coincide with an AC voltage signal passing through its “zero point”).  I have a 9239 analog module in slot 6 of the 9172 chassis (I assume this is where it needs to be to generate a trigger, correct?).
Any help on how to get all of this accomplish would be greatly appreciated.
I am using LabVIEW 8.2.  Thank you!
(3,945 Views)
Ah ha!  I just figured out that having the 9401 in slot 5 or 6 of the 9172 chassis is what is needed to then set up the pulse generator to use either select counter "ctr0" (which is tied to line 3 of the 9401) or counter "crt1" (which is tied to line 7 on the 9401) in the DAQmx Create Channel VI.  This gets me the +5V output I need on the one 2N3904 transistor.
What I would like to do now is to figure out how to trigger start this task when a 60 Hz AC voltage on one of the 9239 module's channels passes through a "zero" point.  I also have a 9215 AD module if the 9239 can't generate an analog trigger start.  Any ideas how to setup an analog edge trigger with either the 9239 or 9215 module?
(3,936 Views)
Accepted by topic author MJHanagan
Hi MJHanagan,
Neither the NI 9215 nor the NI 9239 has analog trigger circuitry built in. However, you can acquire data continuously and scan for a trigger condition in your application. DAQmx includes a shipping example that shows how to do this: LabVIEW\examples\DAQmx\Analog In\Measure Voltage.llb\Cont Acq&Graph Voltage-Analog SW Trigger.vi. It's also on the web: Continuous Acquisition with a Software Analog Start Trigger.
Brad
Brad Keryan
NI R&D
(3,926 Views)
Hello Brad - thank you for that valuable insight, I can now stop banging my head against the wall!  I'll give your software approach a try.
(3,900 Views)
