Pump control
Hi, I'm developing the following programme to control a sensor level usig a DAQ USB 6001 and the level sensor. I have thought in this 3 states: Low level, normal level and high level. I want to control a pump acording to the level of my tank so if the level is low the pump should be activated and if the level is too much (high level in this case) it should be desactivated. What i want is, if the pump is activated because the level is low, it should stop only when the wate,r or any other liquid, reach the high level and the pump should be activated when the water reach the low level. In my programme the pump is activated when the liquid reach the low level but it stops whe the liquid reach the normal level. Any solution? I'm stucked 😞
 My programme is in spanish so low level is "Nivel bajo"; normal level is "Nivel óptimo" and high level is "Nivel alto"
(2,755 Views)
Accepted by AitorGutierrez
Hi Aitor,
IF level <= low_level and previous level > low_level THEN pump:=ON
IF level >= high_level and previous level < high_level THEN pump:=OFF
All you need is a shift register to store the previous level…
Similar solution:
IF level <= low_level AND pump==OFF THEN pump:=ON
IF level >= high_level AND pump==ON THEN pump:=OFF
Again you need a shift register to store the current state of the pump…
Btw.
  • This is a typical task for students in LabVIEW beginner courses, the very same question has been asked lot of times before. Did you search this forum for similar problems?
  • This task typically is known as a simple control scheme, similar to a hysteresis switch. This also has been discussed before in this forum…
(2,724 Views)
