Purge Bluetooth 'Buffer'
Hello All,
I have developed a Bluetooth application (for PDA & PC - LV8.5.1). The application allows the operator to change the Bluetooth friendly name.
If the name is changed, whenever LV searches for BT devices, the function still returns the old friendly name. I have to reboot the PC to get the software to pickup the new name. Is there some kind of buffer that needs to be cleared/reset?
Thanks in advance
ssk
(2,605 Views)
Hi ssk
can you clarify exactly what you are doing here as I would agree with you that if a restart is solving the problem currently then some kind of memory buffer prob exists but I'm still not clear how you are changing this "Bluetooth friendly name"
will you attach your code so that I can run it and get a better understanding.
thanks
Graham Green
Software Product Marketing
NI | Emerson
(2,586 Views)
