Put IP's that answer into a list?
Hi qweewq,
as you want to put strings into an array I would guess it's a string array indicator.
Did you read the context help on snippets? Did you do any beginners courses for LabVIEW?
Message 11 of 24
(1,236 Views)
Yes i did read about it but i use Linux and have some problem open to download and open up files so i have to do it manually.
I cant find something called string array indicator anywhere even if i search. Is string array indicator the exact name?
Message 12 of 24
(1,231 Views)
Hi qweewq,
something you should learn in LabVIEW 101 course:
You pick an array indicator. Then you pick a string indicator and drop it into the array indicator. Now you "magically" created a string array indicator.
I really advise you to go through all those FREE online courses offered by NI. You seem to need that…
The minimum knowledge I expect from someone using LabVIEW to create programs is to read the first chapters of the LabVIEW help!
Message 13 of 24
(1,228 Views)
I have watched a lot of YouTube videos but it did not help me in this case. As you say if you put a string indicator into an array magic will happen but i cant find anyting called array indicator and can not recreate your pink string arary indicator that way.
Message 14 of 24
(1,223 Views)
Hi qweewq,
the array indicator is found on the array palette, string indicators on the string palette…
Message 15 of 24
(1,217 Views)
I find the string indicator but not the array indicator. I use LV2009 maybe thats the problem?
Message 16 of 24
(1,221 Views)
No. Arrays exists from LV1 on…
Message 17 of 24
(1,217 Views)
Huh strange. How come i cant find it. Cant even fint it when i search for array indicator...
Message 18 of 24
(1,215 Views)
Strange.
It's labeled quite straight in the palettes:
Come on. Do those LabVIEW beginner courses. They are for free!
Message 19 of 24
(1,212 Views)
Hello GerdW,
It might be that he is litterally searching for "array indicator".
This will not give any results in a default LabVIEW Palette.
He should better search for "array" and then drop  his "string indicator"  in the array shell on the Front Panel.
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 20 of 24
(1,194 Views)
