Put IP's that answer into a list?
I solved it now. First i did search for "array indicator" and second i did the right thing a couple of times but since i had" view as icon" on in settings i got confused and thought did wrong since i never got that same smal pink icon.
Now i wonder if it is possible to put all IP addresses i have in my array in a combobox? I tried to put a combobox in my arrar but then the drop-down menu dosesent work which is the point. How do i solve that?
Message 21 of 24
(630 Views)
Hi qweewq,
now you need to go through all those free online courses to learn about property nodes!
You want to change a property of the combobox as you want to set it's strings. Well: there is a property named "Strings[]"…
For the icon view:
I guess most experienced LabVIEW users disable the icon view for those reasons:
1. It takes too much space in the block diagram.
2. Using LabVIEW for longer we are used to the "small" view as that's the "original" one.
3. In the BD you are interested mainly in the datatype, but not the look of the FP control…
Message 22 of 24
(622 Views)
Okay thanks!
Message 23 of 24
(620 Views)
Thanks for the update!
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 24 of 24
(609 Views)
