Putting string value into a table
Accepted by CJBee
No, if you use build array, the new row is always appended at the end of the existing table. No math needed.
Here's a quick example (LabVIEW 2013):
Message 11 of 14
(1,449 Views)
Thank you so much, that example really cleared up the misconceptions I had. Got it working, appending each different RFID to the table.
One thing i'm unsure on, is the constants going into the left shift register. I understand that it sets the row and column initially to 0 fwhich the shift registes then update. Context help names it as table control with no description. Just wondering how you created it?
Thanks again
Message 12 of 14
(1,439 Views)
Either place an array constant and place a string in it, or you can r-click the table indicator and select "create constant", or on the 2d-wire. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 13 of 14
(1,434 Views)
Ah yes, ok I finally understand. Sorry for my stupid questions. Thanks everyone
Message 14 of 14
(1,431 Views)
