Python 3 compatibility with labview programs
Hello, I have a question regarding the compatibility of Python3 with a control program created with labview:
Basically we have a vacuum chamber with several motors and gauges controlled by a labview program in Windows 10, I was wondering If I am able to install Python 3 in this machine to run non driver related scripts without interfering with the labview control program?
Thank you for your time!
(3,534 Views)
Accepted by ED_123
hi ed,
running labview and python2/3 side-by-side should be no problem at all.
especially when you don't try to control the same hardware with both programs at the same time 😉
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
(3,527 Views)
Accepted by ED_123
As long as both programs don't use too much resources it should be OK.
When Python (or LV) starts using a lot of CPU, memory, network or disk bandwidth, they might obviously interfere.
(3,507 Views)
