Python 3 compatibility with labview programs
Hello, I have a question regarding the compatibility of Python3 with a control program created with labview:
Basically we have a vacuum chamber with several motors and gauges controlled by a labview program in Windows 10, I was wondering If I am able to install Python 3 in this machine to run non driver related scripts without interfering with the labview control program?
Thank you for your time!
(3,513 Views)
Accepted by topic author ED_123
hi ed,
running labview and python2/3 side-by-side should be no problem at all.
especially when you don't try to control the same hardware with both programs at the same time 😉
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
(3,506 Views)
As long as both programs don't use too much resources it should be OK.
When Python (or LV) starts using a lot of CPU, memory, network or disk bandwidth, they might obviously interfere.
(3,486 Views)
