Python Node with file path as input parameter
Hi All,
I'm not able to use a Python node that use a path as input.
I also try to use a string and then convert it to a path inside the python code but in any case I always have an error message that file path does not exist.
I'm using LabVIEW 2019 and if I run the python code with PyCharm It works with the same file at the same path.
Regards
Golzio
(5,206 Views)
@golzioge wrote:
Hi All,
Regards
Golzio
Which Python.exe are you using in PyCharm?
(5,175 Views)
Accepted by golzioge
thank you for your time.
I'm using Python 3.6.4 64 bit version and also LabVIEW is 64 bit.
I solved my issue simply passing the path as a string replacing \ with / (I already did this before asking here).
The key point was not using quotation mark for path when calling the code from Python node.
Just to be clear:
a= pd.read_csv('File_Path')   ERROR
a= pd.read_csv(File_Path)    OK
All the best
Golzio
(5,159 Views)
