Python and Shared Network Variables
@gemoco wrote:
Do you have or can you point me to an example of the TCP/IP method of sharing variables between two computers?  I am new to LabVIEW and not very savvy on TCP/IP communications.  I am trying to run a LabVIEW VI on one PC which is acquiring data (temperatures and pressures) from a cDAQ-9189 and I want to "publish" 4 or 5 values on the network that will be read by a second computer running a Windows application.  Thank you for your help.
See Basic TCP/IP Communication in LabVIEW
You can also consider using Web Services. See Tutorial: Creating and Publishing a LabVIEW Web Service to the Application Web Server (Real-Time, Wi...
Message 11 of 11
(635 Views)
