Q: How to call DLLs directly
Dear fellas,
I want to use "Call Libary Funtion" to call DLLs by Borland C++. The C
program is a very easy one:
#include "extcode.h"
int32 easydll(int32 x);
int32 easydll(int32 x){
int32 y;
y = (x)+900;
return y;
And easydll.dll was successfully built. But while I configured the DLL
on the LV diagram (function Name set to: easydll), it said:
"The function name specified for this node cannot be found in the
library. Pop up on the Call Library Function node and select
Configure..., then choose the correct function name"
I don't want to use CIN to call DLLs(it worked). I just want to call
DLLs directly. Anybody has idea? thanks a lot.
Guoxiang Chen
Ph.D. Candidate
Ohio Unveristy, Athens, OH
Sent via Deja.com ht
tp://www.deja.com/
Before you buy.
(3,102 Views)
The problem may be that LabVIEW will only find a function defined in C,
not C++. In the header file for the DLL you should be able to redefine
the function as C, rather than C++.
Sent via Deja.com http://www.deja.com/
Before you buy.
(3,102 Views)
