I forgot to multiple numElmts by float32:>)
it works now. Thanks!
In article <37BE0B44.DB455112@austin.rr.com>,
GMCKASKLE@austin.rr.com wrote:
> > I am using CINs(code interface Node) to process some array stuffs. I
> > know the CIN function setCINArraySize() is good for allocating
memory
> > for an output array. But how can I declare an array for CIN's local
use?
> > I tried to use:
> > float32 *array=(float32 *array)malloc(numElmts);
> > and, also, I tried to use:
> > TdHdl **array;
> > NumericArrayResize(int32 fS, 1, (UHandle *)array, nx);
> > Unfortunately, both of them caused illegal operations.
> There is a header file included in your CIN. It exports some
> functions like DSNewPtr, DSNewHandle, DSDisposeHandle, and
> DSDis
posePtr.
> I'm a little surprised that a call to malloc crashed, but I
> haven't tried it in a very long time; so it might be necessary
> to use one of the ones listed above.
> Greg McKaskle
Guoxiang Chen
Ph.D. Candidate
Ohio Unversity, Athens, OH
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
