Quadrature Decoding
@GerdW wrote:
Hi Ambrose,
did you read the Wikipedia article I linked above? Did you understand the part explaining AB/Quadrature encoders with rotary encoders as example?
You need to get the current state of A and B and compare them with their previous state. The tables show you the possible combinations and their meaning (forward/backward movement).
Comparing boolean signals is easy - as shown above. Comparing numeric values is also easy using simple comparision functions!
Here is my vi. I tested already. but the counter din get correct way. If in A lead B mode every rising edge of channel A the counter will count up and if B lead A mode every falling edge of the channel A counter will count down. I testing so many time i still cant get it.
Message 11 of 29
(5,168 Views)
Right now I'm limited to LV2014. Can you attach a downconverted version of your VI?
You need to attack the problem from the other side (as shown on Wikipedia): you check the current state of A and B and compare with their previous states to decide between "A leads B" or "B leads A" (count up/down)!
Message 12 of 29
(5,166 Views)
Here the vi i downconverted to Labview 2014. Thank you so much.
Message 13 of 29
(5,162 Views)
Accepted by topic author Ambrose1464
Hi Ambrose,
see this:
Message 14 of 29
(5,152 Views)
@GerdW wrote:
Hi Ambrose,
see this:
I still confusing what you mean PI=3 and CI=2 then count down??? the control a and b is it same as my vi after first case structure output a and b?
Message 15 of 29
(5,145 Views)
@GerdW wrote:
Hi Ambrose,
see this:
Hi GerdW, Thank you so much for your helping a lot. Finally I understand what you say PI=3 and CI=2. I get the result I want d. I'm appreciated it.
Message 16 of 29
(5,154 Views)
How i going to compare the A lead B and B lead A ? If A lead B will go to rising edge case then counter count up and B lead A will go to falling edge case then counter count down. Here is my vi below. Once I build thealgorithm the counter will count up and down together.
Message 17 of 29
(5,143 Views)
Hi Ambrose,
yesterday you got the result, today you ask again?
And why did you create a new thread on the same topic? Please stick with one thread per problem…
You don't need to check for rising/falling edges. All you need to compare is state of AB with their previous state!
Message 18 of 29
(5,130 Views)
According my vi, i directly make it true or false (mode control) statement for comparison, i found that did not compare the signal A and B by itself. That why I ask again.
Message 19 of 29
(5,122 Views)
It's again a LV2015 VI. Please upload a downconverted version…
Message 20 of 29
(5,119 Views)
