Quadrature Decoding
@GerdW wrote:
It's again a LV2015 VI. Please upload a downconverted version…
Sorry. here it is the LV 2014 vi.
Message 21 of 29
(3,715 Views)
Hi Ambrose,
according to the tables shown in the linked Wikipedia article you need this logic:
IF RisingEdge(A) AND B THEN "count up"
IF FallingEdge(A) AND NOT(B) THEN "count up"
IF FallingEdge(B) AND A THEN "count up"
IF RisingEdge(B) AND NOT(A) THEN "count up"
IF FallingEdge(A) AND B THEN "count down"
IF RisingEdge(A) AND NOT(B) THEN "count down"
IF RisingEdge(B) AND A THEN "count down"
IF FallingEdge(B) AND NOT(A) THEN "count down"
You can combine those IF-THEN statements when ORing their conditions…
To detect edges on A or B you could use the BooleanCrossing function!
Message 22 of 29
(3,713 Views)
@GerdW wrote:
Hi Ambrose,
I need to implement this vi on my fpga, is it effective? I feel take many resounces and the boolean crossing function I dunno how to use although i see the detailed help then that why I din implement on my vi. Mind you draw an example vi for me ? Thank you.
Message 23 of 29
(3,710 Views)
Hi Ambrose,
it's the first time you mention the FPGA part…
The BooleanCrossing function is not available on the FPGA, use a feedback node with a boolean function instead (as shown before, so there's no need to attach another snippet). All the remaining comparisons are quite "small" on the FPGA!
Message 24 of 29
(3,707 Views)
@GerdW wrote:
Hi Ambrose,
Let ignore the FPGA part first, from the picture below, i currently having the problem is detect the edge of A and B during A lack B case. Because A lead B i can compare the rising edge of channel A in the same time, then the A lack B case I dunno how to function it since the falling edge of channel A is not at the same time when A lack B. Currently i can produce the output because i direct set into 2 mode which A lead B and A lack B which din not detect the edge of the A and B.
Message 25 of 29
(3,689 Views)
Hi Ambrose,
it's nice to show some FP artwork, but without knowing your current VI we cannot troubleshoot your problem! (You know I prefer LV2014, don't you?)
Did you implement the IF-THEN logic I told you before?
Btw. use "lag" instead of "lack" 😄
Message 26 of 29
(3,685 Views)
@GerdW wrote:
Hi Ambrose,
I test already. I feel that is the problem of timing. If can try modify my vi see how it works. Thank you.
Message 27 of 29
(3,680 Views)
Hi Ambrose,
you need to implement ALL conditions.
And you need to implenent the edge detection in your main loop - do not hide them inside case structures (THINK DATAFLOW!)…
Message 28 of 29
(3,675 Views)
There is some fundamentel that you need to look.
You need to take a step back and look at your signals, and look at the wiki and the text code that GerdW posted.
Lets take the first step.
When A leads B you need to count up.
When A lag B you need to count down.
We start by only look at the signals when A changes from False to True, a rising edge.
What is the value of B, when A leads B ?
What is the value of B, when A lag B?
( Dont use your mode button for the counting, only rely on the signals)
Message 29 of 29
(3,669 Views)
