Quadrature encoder interface to PCI-6229
Glad to inform that the  encoder link up went about like a breeze and the readings obtained are very stable.
The coding was done based on the attached  VI and virtually no modifications were required. It worked the first attempt.
However I noticed one behaviour : the angle value is retentive. Meaning even after the encoder has stopped, the value remains which is a good thing and expected.  Now how do  I clear the stored value in the  DAQmx read function ? Since  I am using an  incremental encoder, there are many occassions where I would like to "zero" the reading and take fresh values from that point  onwards.
 I am also trying , but can someone modify the attched VI to include an on-demand  reset button ? ( wheels must not be re-invented  Smiley Wink )
Thaanks
Raghunathan
Raghunathan
LabVIEW to Automate Hydraulic Test rigs.
Message 11 of 16
(1,932 Views)
Raghunathan,
The easiest way to do this would be to stop and restart the task. Another option, which would not require a restart, would be to have a boolean on the front panel control a digital output which is internally routed to the Z index of your counter. Of course, this would require your A or B line to be in some pre-determined state for the Z index to trigger a reset of the count register.
Hope this helps,
Ryan Verret
Product Marketing Engineer
Signal Generators
Message 12 of 16
(1,748 Views)
' The easiest way to do this would be to stop and restart the task. "
Looked easy . But could not implement it so easily. Would be glad to get some ideas on the implementation with the attcahed VI as a sample.
( I cannot use the Z- bit as the required condition for A,B channels are difficult to be met  by software alone )
raghunathan
Raghunathan
Message 13 of 16
(1,734 Views)
OK I think I figured it out. I am attaching the VI where  I have added this functionality. But will have to wait till I get back to the machine to try it out. In the meanwhile any corrections may  please be pointed out.
raghunathan
Raghunathan
Message 14 of 16
(1,726 Views)
Chris,
The Measurement Hardware Driver Development Kit (MH DDK) forum is available here:
http://forums.ni.com/ni/board?board.id=90
Please search these forums for a solution, and if you cannot find one, try your post there.
Hope this helps,
Ryan Verret
Signal Generators
Message 15 of 16
(1,714 Views)
Hey people,
I've been looking for the info about the ctr0 and ctr1 for months!!!! well actually I didn't even know about those when I began with my encoder problem.  Anyways thank you guys works perfect now.
ZZ
Message 16 of 16
(1,389 Views)
