Quadrature encoder position acquisition on FPGA using the NI-9361
I’d like to ask you about reading quadrature encoder position signals in an FPGA environment using the NI-9361. In X4 mode, I followed the example program to write my code, but I still cannot get any data. I am using a loop timer together with a flat sequence structure to form a timed loop for acquiring the position signal.I’m very sorry that I only have a Chinese version. I hope to get help from everyone!
(260 Views)
Hello XM34,
I would like to ask you about using the NI9361 to read the quadrature encoder position signal in an FPGA environment. In X4 mode, I have been following the example code, but I am unable to obtain any data. If possible, could you please share your program as a reference? Thank you very much!!!
(281 Views)
What model of cRIO are you using? If you are using cRIO-904x/5x, you can test with Real-Time DAQmx mode first.
How did you connect the sensors? Can you show a wire diagram? By any chance, if the wiring works for Scan Engine or DAQmx mode?
https://tmesystems.net/
(204 Views)
Thank you for your reply, ZYOng! I am using the CRIO-9043. My sensor is a Renishaw optical displacement sensor with a total of 6 wires, and the wiring details are shown in the diagram. According to the NI-9361 datasheet, counter 0 is connected with A and B to DI0 and DI4, respectively. I will try testing with DAQmx, but ultimately I still need to read the data in the FPGA environment.
(196 Views)
Make sure the connection works with DAQmx mode before implementing with FPGA mode.
Did you connect an external power supply?
(185 Views)
Yes, I have connected the external power supply, and the sensor shows normal power supply. Also, during the recent DAQmx test, with the same wiring setup, I was able to collect data normally. However, since the sampling rate of DAQmx does not meet the requirements, I need to implement it in the FPGA.
(178 Views)
It works fine in DAQmx, so I believe the issue is with my FPGA program. The difference between my setup and the example is that I configured the I/O method for the NI-9361 module in the FPGA project properties, setting it to "Quadrature Encoder Position," instead of doing it inside the VI.
(169 Views)
