Query about the reference manual for CAN HS/FD Interface NI-XNET USB-8502
I am a beginner and trying to learn CAN HS/FD Interface NI-XNET USB-8502. I was looking for the reference manual of this device to configure it with LabVIEW.
Best regards
Anik Chowdhury
(4,165 Views)
Couldn't find it either, or is it in the ni.help files?
These is a nice writeup for starting with CAN:
http://hooovahh.blogspot.com/2017/03/can-part-2-can-basics.html
(4,127 Views)
Thank you for your precious reply. I couldn't open the ni.help files. Can you please tell me whether the NI-CAN libraries can be used for NI-XNET? Or Do I have to use different libraries? I have a VI file which was designed for NI-CAN. Can I use it for NI-XNET? Thanks in advance for your help.
(4,117 Views)
Accepted by Anik123
https://www.ni.com/en/support/documentation/supplemental/21/migrating-ni-can-applications-to-ni-xnet...
See if this helps, it doesn't specifically mention the 8502 but the concepts should still be the same
(4,115 Views)
