Query for Appropriate cDAQ card
I have 30VDC (Sinking/Sourcing) inputs to generate from cDAQ. Can I use NI 9485 module for this purpose. I have this question because it shows switching voltage is 60VDC.
Prashant
Message 1 of 9
(4,091 Views)
I have 30VDC (Sinking/Sourcing) inputs to generate from cDAQ. Can I use NI 9485 module for this purpose. I have this question because it shows switching voltage is 60VDC and I also wants to drive 60 VAC from cDAQ please suggest the module.
Prashant
Message 2 of 9
(4,085 Views)
Hi Prashant,
The NI 9485 cDAQ module supports switching of voltages up to 60 VDC or 30 VAC_RMS.  This means you will be able to use it with 30 VDC, as long as it falls within the current limits of <0.75 A when using more than 4 channels, and <1.2 A when using 4 or less.
As for supplying 60 VAC, there is no module that is capable of doing this.  For this purpose, you may need to look at getting an AC power supply that connects to a computer via GPIB, serial, or USB.  You can then program it using LabVIEW along with the cDAQ modules.
Brian
Brian G.
Message 3 of 9
(4,074 Views)
Could you please elaborate second paragraph?
Prashant
Message 4 of 9
(4,061 Views)
Hi Prashant,
Sure, you mentioned that you wanted to drive 60VAC from a cDAQ module.  Does this mean you want the module to switch an input 60VAC signal with a relay, or actually generate a 60VAC signal from the module?  The 9485 can only handle switching up to 30VAC_RMS, so it will not work to switch 60VAC.  If you would like to output a 60VAC signal with a cDAQ module, this will not be possilbe becuase NI does not make any modules capable of this level of AC current output.  This is where I would recommend using a separate AC power supply that can be controlled via an interface like serial or GPIB.  These will be able to be controlled by LabVIEW in order to supply this type of signal.  Let me know if this helps.
Brian
Brian G.
Message 5 of 9
(4,051 Views)
I just want to generate only 30 VDC and 50 VDC from 9485 module not 60VAC or any AC. Comment
Prashant
Message 6 of 9
(4,047 Views)
Your original post says:
"Hi,
Prashant"
What sort of comment do you expect?
Message 7 of 9
(4,042 Views)
1. I meant that suggest a seperate module for 60VAC.
2. and Confirm 9485 60VDC module will work for 30VDC and 50 VDC generation
Prashant
Message 8 of 9
(4,037 Views)
Accepted by UPRR
Both of your questions have already been answered. Since 50VDC is less than the maximum of 60VDC, why do you need any more clarification? Then, you have also been told that NI does not make a card that can generate 60VAC.
Message 9 of 9
(4,034 Views)
