Query property names from TDM file
I am using TDM files to save data from a test.  In the File level, I am inserting a number of custom property tags (using the Set Property.vi in the File I/O -> Storage -> Advanced Storage pallet).
Is there a way to query the names of these properties after the file has been written?  For example, if I put in a custom property "TestLocation", is there a way I can find out the name of this property later, so I can read the value out?
JoeG
Joe Gerhardstein
Viasat
Certified LabVIEW Architect
Certified TestStand Developer
http://www.viasat.com
(3,517 Views)
List Properties in the Advanced Storage menu.
Ton
My LabVIEW Ideas
(3,511 Views)
Thanks, Ton.
However, this only lists the default properties for the Object Type.  E.g., for the File Level, the only properties that are listed are Name, Description, Title, Author, DateTime, ChannelGroups, RegisterTxt1, RegisterTxt2 and RegisterTxt3.  If I have custom properties that I have implemented, such as TestLocation, these are NOT listed.
Do you know a way to list the custom properties?
Message Edited by Joe Gerhardstein on 01-07-2009 02:59 PM
Joe Gerhardstein
Viasat
(3,506 Views)
Accepted by Joe_Gerhardstein
Hi Joe,
Please try the attached VI for custom properties names.
Best Regards,
Mavis
(3,483 Views)
Thanks Mavis.  That works.
Out of curiosity, is this documented somewhere, or insider knowledge?
Joe
Joe Gerhardstein
Viasat
(3,462 Views)
Joe, I don't think it's been documented, unfortunately......Smiley Sad
(3,431 Views)
