 gmacca01
			gmacca01
			02-12-2015 12:57 PM
I have a PXIe-1085 Chassis and the following boards installed:
Slot 10: PXIe-6674T Timing Module
Slot 02: PXIe-7966R FPGA
Attached to the PXIe-7966R FPGA Is an AT1120 adapter module.
I'm trying to supply a 125 MHz clock from the DDS output of the 6674T to the backplane in order to the feed the DSTARA clock to the PXIe-7966R and subsequently to the AT1120 adapter module as the DAC clock.
I'm currently using a modified version of the AT-1120 Getting Started project (https://decibel.ni.com/content/docs/DOC-26331) and have the Adapter Module set to take an internal clock and from FPGA clock as specified in the AT-1120 user manual:
Solved! Go to Solution.
 Ben_S
			Ben_S
			02-12-2015 03:35 PM - edited 02-12-2015 03:40 PM
GMac,
Hello!
There are three things that I think in combination will resolve this issue.
1. ) You may not have included it in your screenshots, but there is an additional step that you must do to use DSTAR A. The bitfile you are using must be complied with a setting that tells the FlexRIO to use the DSTARA signal.
2.) Also, The issue you are seeing was a known issue that was fixed in Active Techonologies (AT) latest software update (version 1.8). While I am not 100% certain, I do not think the Getting Started Example has been updated to contain all the VIs from ATs software update. Likewise, the bitfiles provided with that example would not have been generated with the CLIP included in the latest software version.
I would suggest the following:
3.) Generate a 125MHz signal from the 6674T, not 124.98MHz. The hardware is expecting a 125MHz signal. The dialog window says 124.98MHz due to a workaround for an odd sitiuation that was causing compilation failures.  If you'd like more info on this, let me know and I'll fill you in. read this forum post: http://forums.ni.com/t5/LabVIEW/7966R-DSTARA-Clock-and-AT-1120/m-p/2932916#M847692
I hope this helps!
02-12-2015 05:50 PM
Dear Ben,
You are correct, it was a two-fold issue, I needed to set the io mod sync clock on my adapter module clip properties, and I also needed the updated VI's from version 1_8 from Active Technologies. After that it worked great!
Thanks for your help!
Best,
-GMac
 Ben_S
			Ben_S
			02-13-2015 08:30 AM
GMac,
Glad to be able to help!
03-29-2015 05:01 PM
Dear Ben,
I have another question regarding the updated software/code for the AT-1120.
It seems now that when I stop the VI, and try to re-run it (a modified version of the getting started again), it throws an errror (DCM doesn't lock and DAC is not aligned). However on another re-run of the VI it works fine again. That is every other re-start works fine, the alternating re-starts of the VI fail. Any idea why this may be? do you think it's another software change from Actiive Technologies? I didn't see this issue with the previous VIs/code.
Any advisement woud be great.
Best Regards,
-Gmac
 Ben_S
			Ben_S
			04-01-2015 11:30 AM
Gmac,
That is odd! I haven't seen that behavior before and wouldn't expect that to be the correct behavior either.
Do you see the same behavior if you use the examples that ship with the AT software rather than the updated/modified getting started example?
05-05-2015 07:25 PM
Hi Ben,
I was able to solve this issue a while back, my apologies for not responding sooner!. If I did not reset the 6674T and/or set it up before running the FAM and FPGA, then that is when the issue occured.
Best,
-Gmac
 Ben_S
			Ben_S
			05-06-2015 09:24 AM
Gmac,
Glad you were able to figure it out! Thanks for posting back to let everybody know what the root cause was.
Have a great day!
