Question about LabVIEW Application Builder Installers
Hey,
I am having a strange issue with my Application Builder. When I go to build my application, it says I need NI Visa 18.5.
I downloaded the Full Visa 18.5 Installer and ran it. I unzipped it on my desktop then ran the setup. Everything completed.
I was able to run my application builder.
Once I delete the folder on my desktop, the application builder stops working.
It seems to be referencing that folder. Why is it not referencing the install I just did? Is there a way to work around this?
I see a message box that I can click to minimize popups during build, but when I check it, LabVIEW complains about admin rights, even though I have admin rights.
Any advice? Thanks in advance.
(1,820 Views)
Hi DBISI,
it references the sources used for installation.
I usually copy the installation package for NI software on my harddrive. (Until now I get a new thumbdrive each 6 month, with about 30-40GiB of packages…)
(1,814 Views)
Thank you for the reply.
That's strange... I don't remember it being that way before.
I copied my installer to a local directory.  I just have to remember it's there.
But what does this message mean (see attached)? I have admin rights so I don't understand it.
(1,779 Views)
Accepted by DBISI
Hi DBISI,
I never had that before.
At work I still use LV2017, which does not use VIPM.
At home I use LV2020, installed via VIPM, but there are no issues creating executables.
With Win10 there's a difference between "having admin rights" and "runnning an app with elevated rights": you need to explicitely start the app with elevated rights!
(1,755 Views)
Ah, of course. Windows and it's goofy Admin rules...
There is no option to right click the project and open as an admin, so I had to do that with the LabVIEW application and go the long way around. That silenced the error.
Thank you very much.
(1,739 Views)
