Question about LabVIEW standard "Recover" procedure for when LV quits out/crashes
Hey folks,
Based on the posts I read in my search I'm expecting a little heckling regarding that fact that I'm not using versioning control etc, but I want to ask this anyway (and I'm not sure if versioning woud have helped because I only opened-edited-closed once so far)
Last friday, I took the framework of project A and started reqworking it (renaming things, repointing classes etc) so that it can be the framework for another project I'll call project B.
I really don't think I left the project open or anything, and I know I saved it off as project b (using save as, in a different location).  However, when I went to open the project this morning, some strange things happened and it prompted me with that "recover vis that were open when labview was not closed properly" - I selected "compare vis" for one or two of the vis and long story short I ended up hitting cancel.
My question is simple- is this recovery information stored anywhere else if I change my mind and want to either do more comparisons or do a recover?
EDIT:  TL;DR:   If I were to mess up and click "cancel" instead of "recover" is there ay way to go back and recover or review the code differences afterwards?
thanks
-pat
(2,427 Views)
Hi Pat,
I haven't been able to turn over anything identifying if/where that information is stored.  Unfortunately, I think you may have lost your chance when you hit cancel.
Dave C.
(2,376 Views)
Thx for the response- I ended up scrapping the new project and starting over- seems to be going ok this time around
-pat
(2,363 Views)
