Question about color of Graphs
Ihave just a little question.
I have one application Select plot.vi, I' d like to fix the color of each curve so that there remains the same one some is the selected number of curves.
For running continuously my application: I click on the button «Valider», I choice the list of the curves which I wish to post.To stp
Will be able you to throw a glance in my VI Select Plot.vi
I don't know how is my problem ?
I thank you in advance,
My best greetings,
Nadine
(2,464 Views)
I would not write the plot names at all, these names are already contained in the data so you are constantly fighting.
You might just want to plot all curves, but color some of them transparent according to the check boxes. You should also only change thse properties when the selector changes, and not with every loop iteration. (See attached LabVIEW 7.1 modification).
Message Edited by altenbach on 03-28-2005 11:43 AM
(2,457 Views)
Thank you very much for your assistance.
My best greetings,
Nadine
(2,446 Views)
