collapse an array
Is there a simple tool for "collapsing" an array through addition?
Specifically, I have a 3-d array which consists of a series of 2-d pictures taken with a webcam. I'd like to reduce it to a single picture by adding the pixel values from each 'exposure.' (The number of exposures is non-determinisitic and set by the user at runtime.)
Seems like there should be a pretty simple vi for this kind of operation but I haven't found it yet.
Eric Coppock
Ball Aerospace & Technology Corp
(3,101 Views)
You should be able to use a simple FOR loop that indexes through all your 2D images and adds them sequentially to a shift register. Another possibility would be to feed it through 2 autoindexing FOR loops, containing a SUM operator.
The exact procedure heavily depends on the order in which your 3D array is indexed. It might be easier to slice it using "array index" with some indices unwired.
Do you have a small example array with a few layers? How many bits do you have per pixel and what is the data type? You might need to watch out for overflow.
(3,095 Views)
Dense newbie says "huh?"
Anytime I work with something inside a FOR loop, when I bring it out of the FOR loop it becomes an array of N of whatever it was I was working with inside the loop. That's the problem I'm trying to solve ... I'm not seeing how using another FOR loop is going to fix it.
Sorry I'm being slow. Maybe a picture would help?
EC
(3,080 Views)
Awww jeez, I just discovered the "disable indexing" option on the tunnel exiting the for loop.
Thanks for your help! 🙂
EC
(3,078 Views)
