Question about using LabVIEW to control Keithley 2450
Hello everyone,
I am trying to use labview to control Keithley 2450 by a USB cable. When I used DAQ assistant, it can't recognize Keithley 2450. But when I used I/O instrument, it can recognize Keithley 2450.
I remember I have ever used DAQ assistant for Keithley but with a GPIB cable when I studied in another lab.
Do you think the problem is because of using a wrong USB cable? If I use GPIB to USB cable, will DAQ assistant recognize the keithley?
(1,512 Views)
I don't think that this is a thing that you can do.  The 2450 is an instrument you have to send commands to using SCPI commands, not using a DAQ assistant.
The DAQ assistant is just for devices made by NI... not a Keithley sourcemeter.
(1,505 Views)
