Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
2
Question (table)
Re: Question (table)
dctoni
Member
Author
04-02-2008
07:18 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Hi Partha
thanks for the e.g . . I have work with your e.g and that of Jorge but still have a small Problem with the header column .
the Problem is that i can see just the last Nr. of the steps . what should i do to see all the Numbers.
Toni
Unbenannt 11[1].vi 71 KB
0
Kudos
Message
11
of 12
(770 Views)
Reply
RPJ
Member
08-07-2008
04:26 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Try this. It will at least give you an idea. The solution ads now numbers in the row headers. (I used LabView 8.5)
UnbenanntSuggestion.vi 70 KB
0
Kudos
Message
12
of 12
(731 Views)
Reply
2
All Forum Topics
Previous Topic
Next Topic
