Queue problem,
I have to implement a Queue. In labview Queue input we have to define element data type, What I have to enqueue is a string, How to define the data type for this?
String is like "HA1","HA2"  some thing similar to this. Could you please helop me to do this?
Best Regards,
Paheerathan
(4,573 Views)
Accepted by Pahee
Just wire an empty string constant to data type
Cory K
(4,566 Views)
If it is a single string then just wire a string constant.
If you are going to pass more than one each time you update the queue then wire an array of strings.
If you want to included other info then put the string in a cluster and wire up the cluster to the Create Queue.
Ben
(4,559 Views)
Thanks Cory K and Ben,
Useful information
Best Regards,
Rathan
(4,552 Views)
