Quick drop list doesn't come up anymore :( LV2009f2
My quick-drop list doesn't come up anymore when I press ctrl-space.  When I initially press ctrl-space (after loading LabVIEW) my machine behaves like it is loading the drop list (LabVIEW lags, and my hard drive thrashes for about a minute), but no drop list appears.  My computer is kinda slow and outdated (hense the long inital load times of the drop list) so that may be the issue.  I'm running a 1.6GHz Centrino w/ 1.5GB of ram and Windows XP SP3.
I've tried rebooting.  I was using the drop list quite a bit before it stopped working.  I would like to avoid a full reinstall of LabVIEW over this.
Any advice?
Thanks!
-Nic
(3,562 Views)
I faced this few times. But just restarting LabVIEW helps to recover quick drop
Message Edited by Mathan on 11-16-2009 12:27 PM
(3,560 Views)
I've tried restarting LabVIEW with no luck.
One thing i just discovered is the functionality of the Quick Drop list is working.  I can press ctrl+space and type "add" and press enter and the add function appears.  The drop-list window is not appearing on the screen.
-Nic
(3,547 Views)
Accepted by hecmar.arreola
Just grasping at straws but...
In the LV .INI file there is a line
"QuickDropPosition="
That apperas to save where the QD window waas when last used. Maybe yours is set for an off-screen position.
Ben
(3,534 Views)
Yup, Ben's suggestion is the one I would have made.  This has happened to me in the past when I moved my LabVIEW INI file from a 2-monitor system to a 1-monitor system, and Quick Drop was on the 2nd monitor.
(3,517 Views)
Ben,
Did I ever tell you that you're my hero?
(3,496 Views)
Nickerbocker wrote:
Ben,
No. He is the HERO (common to all) Smiley Wink
(3,464 Views)
