Quick way to convert a 2D boolean array to a 2D number array
I was wondering how I could convert a 2D boolean array to a 2D number array. I want to multiply the boolean array with another one, but I can't because the types are incompatible.
I tried converting to a digital and then a binary, but the binary gives me a 1D array for some reason.
Thanks.
Message 1 of 10
(6,939 Views)
Can you show what you tried that didn't work?
What should the conversion look like?  Is it a case of converting True or False to a 1 or 0?
Message 2 of 10
(6,931 Views)
Message 3 of 10
(6,921 Views)
I'm confused. Do you want to multiply two boolean arrays? Wouldn't that be the same result as just AND-ing them?
Jarrod S.
Message 4 of 10
(6,906 Views)
Sorry, I wanted to multiply a boolean array with a numeric array. (Thanks
Message 5 of 10
(6,881 Views)
Hi
I have 2D boolean array, and I need to convert each row individually to a numeric 1D array like this
0:0:0 ----> 0
1:0:0 ----> 1
0:1:0 ----> 2
1:1:1----> 7
8x3 array to 8x1
I tried by Boolean Array To Number function, but it doesn't work because of the difference in the array dimensions, how can I do that?
Thank you
Message 6 of 10
(6,324 Views)
Convert each row of the 2D array to an integer using Boolean Array to Number inside an auto-indexing For Loop.
CLA
Message 7 of 10
(6,316 Views)
Hi ysma,
"oh all those wonders of AUTOINDEXING"
Message 8 of 10
(6,315 Views)
Thank you very much both of you....Heart
Message 9 of 10
(6,281 Views)
You can thank them by giving them Kudos.
Message 10 of 10
(6,256 Views)
