Quirks of Gmail SMTP quota
I ran into a Gmail security issue, but on the POP access side.  It seems it allows only so many login attempts within a 'certain' amount of time. Although I did not find any documentation that described this behavior.
It occurs to me that if you wrote the VIs on both sides of the email, you could send ONE email with 36 attachments.
Just a thought that circumnavigates the issue.
Paul
Message 11 of 12
(725 Views)
I just found out that the customer's email server is not using SSL. So after swithing off SSL enable in the vi, the customer smtp can be connected.
Regarding why gmail smtp cannot be connected on the ship network but can be connected in a office network , it is still a mystery. The ship has is about to set sail cannot perform gmail smtp tests on the ship anymore.
I did look up a couple of links regarding gmail SSL.
http://www.webmonkey.com/blog/Why_You_Should_Turn_Gmail_s_SSL_Feature_On_Now
http://mail.google.com/support/bin/answer.py?hl=en&answer=13287
http://blogoscoped.com/forum/136498.html
Message Edited by sunflower2772 on 10-28-2009 01:56 AM
Message 12 of 12
(699 Views)
