REVERSE BYTE ORDER
Here's my code in C#:
 // UDP Connection  :: Talker ::
                        Boolean done = false;
                        Boolean exception_thrown = false;
                        Socket sending_socket = new Socket(AddressFamily.InterNetwork, SocketType.Dgram, ProtocolType.Udp);
                        IPAddress send_to_address = IPAddress.Parse("172.22.11.2");
                        IPEndPoint sending_end_point = new IPEndPoint(send_to_address, 80);
                        while (!done)
                            //foreach (Vector3DF[] vector in facePoints3D.GetSlices(n))
                            foreach (Vector3DF vector in facePoints3D)
                                //arrange
                                float zvect = vector.Z;
                                byte[] bytearray = BitConverter.GetBytes(zvect);
                                //convert value to string
                                //string bytearray = Convert.ToString(bytearrays);
                                // Remind the user of where this is going.
                                Console.WriteLine("sending to address: {0} port: {1}",
                                sending_end_point.Address,
                                sending_end_point.Port);
                                try
                                    //sending_socket.SendTo(data, sending_end_point);
                                    sending_socket.SendTo(bytearray, sending_end_point);
                                catch (Exception send_exception)
                                    exception_thrown = true;
                                    Console.WriteLine(" Exception {0}", send_exception.Message);
                                if (exception_thrown == false)
                                    Console.WriteLine("Message has been sent to the broadcast address");
                                else
                                    Console.WriteLine("The exception indicates the message was not sent.");
                            }   //ends foreach statement
                        }  //ends while(!done) statement
                        // ends udp talker
 And I am doing the following in LabVIEW,
Message 11 of 12
(731 Views)
Message 12 of 12
(725 Views)
