RGB Value from Image captured by webcam
Hi, i am doing a labview project in which i have to get RGB value directly from image captured by webcam. I am trying to do get result, but cannot attain RGB values. Help me to clear out this problem!Untitled.png
Best Regards,
Dhans 😉
Kudos are welcome 😉
Aspirant Labview Programmer (Labview 14) 😉
(5,038 Views)
Hi dhans,
why do you think that typecasting the reference to an image (aka "pointer") will result in a (scalar) RGB value?
IMAQ has functions to convert an image reference to an array of RGB values!
(5,019 Views)
Hi, thanks for answer. But i tried that too also. It shows an invalid image type error.
Best Regards,
Dhans 😉
Kudos are welcome 😉
(4,998 Views)
You have an IMAQ Create with nothing wired to image type. By default LabVIEW takes grayscale U8 and creates a space in memory for only that type of image. Wire RGB U32 and see.
(4,981 Views)
And also you shouldn't expect wiring a reference to do typecast to do conversion for you. Use specialized IMAQ functions (extract color plane, color plane threshold etc ) to lend you RGB values.
(4,968 Views)
What do you want?  Do you want the RGB Image split into a "Shades of Red" + "Shades of Green" + "Shades of Blue" set of images, or did you want the value of a particular Pixel expressed as an RGB triple?
If the former, I believe there have been posts on the forum within the last six months on this topic (I recall posting exactly such code which may or may not have been accepted as a "Solution", I don't remember).  Not sure how to find it ...
Bob Schor
(4,951 Views)
