RMS Calculation Wrong
I am attempting to calculate the RMS value (or standard deviation) of an array of numbers.
Instead, what I get out is the MEAN, not RMS.
After digging as deeply as possible into the problem, I find that the built-in Labview 8.0 function NI_AALPro.lvlib:RMS.vi is getting the wrong answer.
I am unable to attach a copy of it here, so I will instead attempt to attach a screen shot.
Any Ideas? Thanks.
(2,887 Views)
Hello ware,
If you are using the "RMS.vi", probe the numeric error code (It does not return an error cluster.) returned by this VI.
Also, the screenshot you mentioned is missing.
Prashant.
(2,879 Views)
