Write to PNG broken?
while creating a VI to report some information I wanted to use the
"Write PNG File.vi". With Labview 8.2.1 under Windows XP everything
works fine. With the same Labview version under Linux "Write PNG
File.vi" and the similar jpeg vi's are broken and can't be executed.
As they are password protected I can't look inside for the cause of
the error.
Does anybody has similar issues with these image vi's under linux or
maybe even has a hint how to fix/circumvent this?
Alexander
(2,978 Views)
Just a guess but this sounds like a library problem. You may be missing a Linux package...
(2,968 Views)
Which version and distribution of Linux do you have? This article references a similar problem to yours and may be helpful. Let me know if this helps!
Amanda Howard
Americas Services and Support Recruiting Manager
(2,935 Views)
