Value (Signalling) call on a non-strict table reference causes error 1058 in LabVIEW 8.5
There appears to be a bug with the "Value (Signalling)" property for a non-strict table in LabVIEW 8.5.
In the attached VI, the first call does not generate an error, but the second (after casting the reference to be non-strict) does.
Am I missing something?
Jaegen
(5,485 Views)
If you right-click on the Table control reference and choose Create > Constant, you'll get a "Table (strict)" reference constant, which, when used with To More Specific Class (instead of the "Table" reference constant), causes the code to work ok.  If you're looking to create a control reference control that you can use in a subVI to pass in the control reference, check out this nugget, where I show how to create one on the front panel that uses the correct datatype for the control.
Good luck,
-D
(5,468 Views)
Did someone leave the door to ivory tower open again?
Thanks for visiting stanger. Smiley Wink
Ben
(5,454 Views)
Notice the time stamp on my response...I had spent so long last night playing Guitar Hero III, I needed something to bring me back to reality before going to bed.  So I picked LabVIEW...  😉
-D
(5,444 Views)
Good luck,
-D
Darren,
I understand all of this - the problem is that I have an existing GOOP class that uses a non-strict reference, and works fine in LV 7.1.1.  Also, everything else works fine except the "Value (Signalling)" property.  The work-around is simply to cast it to a strict reference before calling the property (see the attachment), but isn't this still a bug???
Jaegen
(5,439 Views)
Ok, I verified that the behavior doesn't happen in LabVIEW 7.1.  It does happen in 8.0 and later, though.  I have filed CAR 4F1A1BF2 regarding this issue.  For now, the workaround of using a strict control reference should be sufficient.
-D
(5,434 Views)
