RMS sliding window
Hi Everyone
I am calculating the RMS from a 50 sample window (sampling rate 1000Hz). I am using the Biosignal RMS.vi but I want to change the window to use 25 samples before and 25 samples after the point I want  to calculate. I am still new to labview and have been running in circles a little. Help is appreciated! I have attached the VI I am using along with some sample data.
Thanks again!
(2,825 Views)
(2,809 Views)
