ROI
How can I focus a ROI on a moving dot using a basler camera and meanwhile obtaining the coordinates of this dot on labview? Are there some examples that can do that?
thank you
(2,631 Views)
Accepted by fra24
thank you
It depends which "Dot" you would like to search and from used tools. In assumption that you need to locate contrast dot, you can use simple threshold, then particle analysis, and after that rectangle to ROI (or to point if needed), something like that:
Sorry for slightly "messed" code, it was just "lunch break" example, this is how it works:
LV2018 in the attachment
(2,605 Views)
