RS-485 Exemple missing
Hey, I was trying to open the LabVIEW example but got this erro
It seems like I can't open the example on my end, and I couldn’t find it online either. Could someone please share the file with me?
And if you could just give me some tips, I am just trying to use a serial device (hk-140)
(1,474 Views)
Accepted by MarcusP.
The example you were asking about is attached.  It's my 2021 version, so there is a slight chance it's not the same as what you are using.  The examples don't get updates super often though.
(1,448 Views)
Thanks for the video — I’ll definitely check it out!
As for the example, no worries. I just found out that, for some reason, when I open it, the Explorer opens a different folder. So it still doesn’t work as expected, but the video will definitely help.
(1,424 Views)
Yep, I still dont know what to do, but thanks anyway
Update: I found it and got it to work! Now I just need to understand Modbus RTU and get that working too.
(1,419 Views)
