RS 485 Moxa Industio CP132 Card
Has anybody any expierence with this card?
Sounds like there is am automatic switch between transmit and receive
in half-duplex mode.
So can I use it like an RS232, but giving care not to read and write
at the same time?
Can I use the standard serial VIs?
Has anybody a LabView driver? (there is non delivered with)
Thanks for any hints!
Urs
(2,989 Views)
This is a card for controling comunication via RS485 standard.
With an adaptor you can probably use it like a RS232 (I'm not sure as long as I'm using a 232 to 485 adaptor). Anyway, why bother as long as you have RS232 standard ports.
In order to use this card, you need a driver for it (contact Moxa) and some VI for LV access.
(2,989 Views)
