RS 485 communication via PXIe
i have a PXIe system with certain DAQ-modules in it. In order to communicate with another unit i have to implement the RS485-standard. Is it possible to communicate via Labview or Veristand and the DAQ-modules with this unit? Which program would be more useful and simpler in this case?
Thank you
(2,971 Views)
Hi mihamm,
Which (DAQ) modules do you have available for your PXIe chassis?
NI offerse several PXIe cards for RS485, like this one. This would be the "simple" way…
Which PXIe system do you use? Does it offer a serial port? Then you might use a simple RS232-RS485 converter with that port in case it does not offer a builtin RS485 mode…
(2,963 Views)
Hi, GerdW,
thank you for your answer!
I use the following hardware, which you can see in the screenshot:
It is only a small application i have to realize with RS485 so i think it is not appropriate to purchase a several card, but thank you for that information.
Regards
Michael
(2,946 Views)
A quick google on those part numbers seem to show me that none of them have an RS485 port like GerdW suggested.
The next easiest way would be to use a USB to RS485 adaptor like this....https://uk.farnell.com/ftdi/usb-com485-plus1/mod-usb-fs-to-rs485-1-port-ft232r/dp/1817177?gclid=CjwK...
This will just show up as a COM port which, you should then be able to communicate with this using NI VISA.
(2,932 Views)
Thank you for your answer!
I would have such an adapter available.
Just for my information,  because i never used NI VISA, where should i plugin the USB cable?
Is it possible to connect the RS 485 to the PXI controller?
Michael
(2,929 Views)
Accepted by topic author mihamm
I am not sure I understand your question.
You can just plug the USB adaptor into one of the USB ports on the PXI.
Unless you purchase a card like GerdW suggested you can't connect an RS485 cable directly into the PXI.
If you type 'Serial' into the NI Find Examples wizards a few examples will come up (One specifically for RS485) (Help/Find Examples)
(2,925 Views)
Thank you very much, that was the answer to my question.
Yes, I think I have found a suitable example.
(2,920 Views)
