RT Desktop PC Web Service 64 bits
I am using LabVIEW 2021.
I installed a Linux Realtime Desktop PC.
I am trying to run a web service on it but I get the following error : Error LabVIEW: (Hex 0xFFFEFA29) LabVIEW Web Services: Target OS for this Web service differs from the Web server configuration.
This error means that I have to change the bitness of my Application Web Server. BUT there is no option to do it.
Is it possible to generate the web service for the 64  bits version of the Application Web Service.
I tried to use LabVIEW 2021 32 bits and 64 bits with no success.
Does anyone have an idea ?
Thanks.
Christophe
(2,456 Views)
Accepted by topic author pacome
I finally solved the problem.
I ran the project Web Services – Weather Monitor RT successfully. This an example project.
When I compared my project and the example project, I found that the icon of the RT target was not the same.
RT Desktop Target in my project had not the correct type.
I tried to add the same target type as in the example project with no success. I cannot find the same type.
Finally I opened the lvproj file and I found that the type of the item was RT Generic in the working project and RT Desktop Target in my project.
I changed the type to RT Generic in my project and it worked !!!
I don't know why I cannot choose the generic type from the Add Targets and Devices wizard.
(2,398 Views)
If your previous response is a "Solution", please go there and click "Accept as Solution" to alert other Forum users that you "Solved the Problem".  Good for you!
Bob Schor
(2,391 Views)
You went through the trouble of posting your solution, you may as well give yourself credit for it!  🙂
Bill
CLD
(Mid-Level minion.)
(2,381 Views)
