‎09-03-2012 10:53 AM
the VI "RT Get Memory Usage.vi" is apparently no longer available in LabView RT 2012. The help says to go to ni.com/info and enter a Info Code but this code leads to nowhere. My question is now on how to replace this VI with a LV 2012-compliant pice of code?
Thanks for help,
Christoph
Solved! Go to Solution.
‎09-03-2012 11:43 AM
I guess the VI you have mentioned is available only in the RT target and you will not be able to see that when you create a vi in the host, so create a Target and then create a vi and check it there. Also check whether you have installed the RT toolkit properly.
‎09-04-2012 04:53 AM
‎09-11-2012 04:02 PM - edited ‎09-11-2012 04:06 PM
The RT Get Memory Usage has now been replaced by the function contained in the System Configuration API. You can find the replacement function by browsing to RT Utilities >> System Configuration >> RT Software >> System Node. Drop this node in your code, left-click on it and browse to System Resources. There you should be able to find all of the functions that were previously contained in the RT Get Memory Usage vi.
‎09-19-2012 12:58 AM
Hi Kyle,
that did the trick, thank you for helping!
Christoph
‎10-04-2012 06:43 AM
The properties seems to be there, but from the "System Resources:Largest Available Memory Block" I always get zero on my cRIO-9073 application. Any idea why?
BTW: it looks like they have started to show it in kB, not bytes as previous. Also, it is now represented in double type, without showing the decimals. A bit strange...
‎01-10-2014 12:02 PM
I'm experiencing the same issue with the sbRIO-9636 and LabVIEW 2012 -- Largest Avail. Memory Block returns 0. Has this issue been solved? Prior to reading the LAMB, I read the Serial Number, and that value is correctly returned, so I'm fairly certain I have the System Session opened correctly.
‎03-12-2014 07:12 AM
Thanks for this, I found that opening the session to local host took a couple of seconds so I made sure I only did it once in a loop.
‎06-04-2014 09:35 AM
Did someone has used this "System Hardware" Property Node in cRIO 9068? I need to create some code based on the Memory usage but this node apparently seems not to work with this RT target (ERR -2147467263)
Alberto
‎01-19-2016 01:54 AM
Thanks a lot.
