[RT] Meaning of Timed Loop "reset at structure start"?
Using LabView RT the Timed Loop and also the Simulation Loop have a hardware clock feature called 1 MHz. Each iteration is done in sync with the hardware clock ticks.
But what's the difference between 1 MHz and 1 MHz <reset at structure start>? My guess:
  1. The first option starts the loop with the next hardware clock tick (waiting)
  2. The second option starts the loop immediately (so the loop is running with a "tick offset")
  3. The hardware clock "reset" does not affect other Timed or Simulation Loops running at the same time
Is this correct?
(3,414 Views)
in the following link you can find further information about this topic.
http://zone.ni.com/reference/en-XX/help/371361H-01/lvdialog/loop_configuration_db/
I have a VI attached which shows you the difference between these two options in a practical example. Just try out the different options for the timed loop.
Without <reset at structure start> the timed loop wants to catch up a time delay after its first execution, with this option enabled it still works fine for the upcoming
iterations.
Kind Regards
Thomas
(3,341 Views)
Thank you for your answer. Could you please make a screenshot or save it with an earlier version? I am using LabVIEW 2009 SP1, so I can not open your VI.
As for the link, the explanation about "reset at structure start" is quite brief.
(3,329 Views)
I have attached screenshots now. You just need a Main VI and a Sub VI as you will see.
If you do not use the <reset... function> the timed loop trys to catch up the 1kHz clock after the first run, so that the Sub VI does not work properly anymore.
Kind regards,
Thomas
(3,327 Views)
Did I understand it right according to the picture below?
(3,319 Views)
